Ok guys, big question please.
Old Mar 12, 2004 | 03:57 PM
Pasky's Avatar
Ok I have a 91 camaro I just swapped a LT1 & t56 into from a 95 trans am. I have the cable and the software to program out the EGR and Vats.
However, I don't have a donor v8 fourth gen to do the initial program so I can fire my baby up with the computer.
Now my brother in law has a 95 V6 3.4 camaro. Can I unhook his wiring to the computer, plug the 95 trans am PCM into his connections, turn the key and program out vats and EGR and plug his back in and fire mine up? Thanks.
Old Mar 12, 2004 | 07:55 PM
Pasky's Avatar
Anyone? .
Old Mar 12, 2004 | 08:58 PM
rskrause's Avatar
Moderator
I don't understand the question.
Rich Krause
Old Mar 16, 2004 | 02:03 PM
Pasky's Avatar
Ok, I have my old thirdgen wiring harness i have to splice in with the fourth gen for the lt1. Im not gonna splice the ALDL connector right away (AKA can't disable vats using my thirdgen). NOw my brother in law has a 4th gen 95 v6. Can I unplug his computer, and plug the 95 lt1 computer in and remove Vats, CAGS, and egr using his ALDL port and just plug his computer back so I can fire my car up?
Old Mar 16, 2004 | 02:15 PM
OpCode's Avatar
you can hook up the aldl wires to you thirdgen aldl plug, you may have to repin cant remember. and flash w/ vats off. and a resister to by-pass the vats on the car, in case your key f's up
Old Mar 16, 2004 | 03:16 PM
Pasky's Avatar
Yes, I realize it can be done, but like I said I don't plan on hooking the ALDL up immediatley, I just want the car running for now. Which is why im asking, since I really just need to give the PCM power, can I hook it up to the v6 fourthgen and put the key on 'on' and just reflash.
Old Mar 16, 2004 | 03:45 PM
OpCode's Avatar
i dont think the V6s used the same harness, where are you located, i have a desk top programming setup i could do it for a few bucks
Old Mar 16, 2004 | 04:28 PM
Pasky's Avatar
in Laredo, TX currently.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
Red97LT1
Aug 7, 2002 05:45 PM
