On an OBD2 LT1 car, what happens if a rear O2 sensor is bad?
Something must be wrong with the wiring harness going to my driver-side rear O2 connector, because the O2 sim there blinks, but my scan tool shows that the voltage never changes. The PCM is showing a code for that O2 sensor (bank 1 sensor 2). The passenger side sim voltage fluctuates normally as it should. If I swap the sims I get the same behavior, so it's definitely a harness issue.
If the PCM is getting a bad signal from a rear sensor, does it make any adjustments to the fuel trim? I would guess that it just uses the front O2's to evaluate the mixture, and then uses the rear O2's to make sure that the cats are working.
Any info? Thanks!
Any info? Thanks!
Jul 4, 2005 05:00 PM
