obd1 vs. obd2
Old Sep 2, 2007 | 02:55 PM
maro z28's Avatar
obd1 vs. obd2
can someone please explain some of the major differences in these pcms? Thank you.
Old Sep 2, 2007 | 03:19 PM
infinitebird's Avatar
obd2 is much more complex, has a lot more dtcs and diagnostics.
Old Sep 2, 2007 | 03:36 PM
The basic logic for fuel and ignition control is similar when comparing the LT1 OBD-I to OBD-II PCM's. The main difference is the fact that they added a few sensors (crank position, after-cat O2's, EVAP vacuum switch) and a lot more diagnostic checks, all of which are aimed almost exclusively at emissions. The diagnostics typically have little, if anything to do with fuel and ignition control. There was some modification of the A4 control logic, which appears to overcome problems with high stall converters that were in the OBD-I system.
Old Sep 3, 2007 | 10:40 AM
VinceTrifecta's Avatar
Also, sadly, the performance shift mode switch feature doesn't work on OBD2 PCMs...
Sep 6, 2015 03:10 PM
Aug 24, 2015 06:41 AM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Pullngz
Jul 26, 2015 05:55 PM
