obd1 to usb
Old Jan 1, 2011 | 10:08 PM
DTRJAR's Avatar
Question obd1 to usb
is this all i need to go from my car to my pc and then the tuning program thanks ebay item # 260687588842
Old Jan 1, 2011 | 11:27 PM
Re: obd1 to usb
Copied and pasted the number, and got this - in Italian?? - for Audi, Skoda, SEAT and Volkswagon:
"Veuillez patienter
Image non disponibleAgrandir
USB Vag-Com OBD2 OBD1 Scantool Tech VW Audi vagcom Ross"
You need to copy and past the complete link.
Old Jan 1, 2011 | 11:33 PM
DTRJAR's Avatar
Re: obd1 to usb
i cant find it now can some one help me find the cable i need im going to use tunercar program but i dont want to get the cable from them bc i cant just get it buy it self thanks
Old Jan 2, 2011 | 07:20 AM
Guest47904's Avatar
Guest
Re: obd1 to usb
A little confused here. You say you're looking for an OBDI tool but you have a 95 camaro and it uses an OBDII connector even though the PCM is indeed OBDI.
Your link is to a tool for foreign brands. So are you looking for something to connect to the 95 which uses an OBDII connector or not?
If so this is what you might want.
http://www.aldlcable.com/sc/details.asp?item=aldlobd2u
http://www.akmcables.com/ic.htm
Old Jan 2, 2011 | 09:02 AM
TT350's Avatar
Re: obd1 to usb
http://cgi.ebay.com/ws/eBayISAPI.dll...%3D1&viewitem=
Old Jan 2, 2011 | 09:14 AM
Guest47904's Avatar
Guest
Must be careful
According to this
Originally Posted by speedygonzales
This won't work
On a 95 F Body
Old Jan 2, 2011 | 02:29 PM
DTRJAR's Avatar
Re: obd1 to usb
ok so your saying i need the obd2 if i would hapen to get the one from http://www.tunercat.com/ do i need the 16 pin or the 12 thanks
Old Jan 2, 2011 | 03:15 PM
SkiBumDreams's Avatar
Re: obd1 to usb
you have an obd1 computer, the under dash connector however is the 16pin obd2 style/shape. you need a very specific cable that is obd1 variety with an obd2/16pin connection. http://www.akmcables.com/ic.htm on this page you need the #2 or the y to work with your vehicle because it is a 95. prior to 95 the cars were obd1 with a rectangle shaped 12 pin connection. 96 and after are obd2 computers with an obd2 connection. however in 95 they kept the obd1 computer but went with a "newer" style obd2/16 pin connection under the dash.
you could get a 12 pin style obd1 connector and jumper the pins from the cable to the correct pins on the under dash connection. like is shown on shoebox's sight. http://shbox.com/1/xraycable.jpg
Old Jan 2, 2011 | 07:03 PM
DTRJAR's Avatar
Re: obd1 to usb
thank you for the help
Aug 24, 2015 06:41 AM
whitehooptie
Aug 10, 2015 07:02 AM
Pullngz
Jul 26, 2015 05:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
