OBD1 Scanning
OBD1 Scanning
I recently purchased a OBD1 cable for my laptop to run FreeScan for my 95Z to find out what code or codes my car is storing. Couldn't get freescan to work. Is there another downloadable site to try? The SES light was coming on after my car started breaking up as I depressed the pedal, then it would it would run fine for awhile, feels like a fuel issue.
Re: OBD1 Scanning
Here is a good site for download. Is your cable USB or serial, what OS are you running, is the driver loaded for the cable, have you set up the COM port in freescan, what are you failing symptoms when you try to run it. http://www.andywhittaker.com/en-gb/ecu/freescan.aspx
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
