obd port problem
Old Feb 15, 2012 | 04:50 PM
paxtonLT1's Avatar
obd port problem
Hey guys hope I can get a little help. I'm working on a friends 94 camaro and went to tune it for him but I got no comunication with the pcm. Thought it was my laptop or cable but tested with a scaner at work and same thing. Even tryed a hyper tech programer that will turn on when you plug it into the obd port but then says no comuication, check cable. So I'm thinking its one of the wires from the port to the pcm guess I gota brake out the multimeter...................
Old Feb 15, 2012 | 06:31 PM
moparman's Avatar
Re: obd port problem
Check the fuse. Think the port is on the same circuit as the cig lighter.
Old Feb 16, 2012 | 05:12 AM
There is no 12V supply to the 12-pin OBD-I ALDL connector.
Old Feb 16, 2012 | 11:59 AM
paxtonLT1's Avatar
thats what i thought but i thought it was weird that the hypertech turns on when you plug it it poss triggered by ground? oh well now its time to start checking wires. thanks guys
Old Feb 16, 2012 | 12:42 PM
paxtonLT1's Avatar
ok so pin A is ground. pin B is diagnostic request. pin g is program imput, keyless entry receiver. and pin m is seral data line.key off I have ground on pins A,B,M and 7v on pin g.KOEO I have ground on pin A, 7 volt on pin G, and 4.9v on pins B and m. anyone know if thats all right? seems like it. Im not thinking a damaged wire anymore but a damaged pcm now.
Old Feb 16, 2012 | 01:55 PM
paxtonLT1's Avatar
ok so any reason i shouldn't swap the pcm from my 95 trans am into it. to see if i can get the scan tool to communicant with that?
Old Feb 16, 2012 | 02:29 PM
paxtonLT1's Avatar
ok so to anyone out there interested pcm was bad swaped in my pcm and whata you know it works. still runing like **** and has a code 24
Old Feb 16, 2012 | 04:48 PM
If his 94 Camaro has the A4 trans, there will be a mismatch with the TC lockup signal from the the 95 PCM (on/off in the 94 vs. pulse width modulated in the 95).
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
