obd I question
Old Jul 8, 2005 | 06:01 PM
camaroken's Avatar
obd I question
I just bought an 88 iroc 305 tpI, cheap money. it had no ses bulb in it. i installed 1 and tried to pull codes by jumping the a and b pins. no flashes nothing. light on solid. at first i thought maybe no ground to the pcm. but the light stays on with key on and when started light goes out. well now the light comes on when the car is running which means i have a code and or problem, but i still cannont jump the a/b terminals to pull the codes. just wandering if you guys have seen this and any ideas? I will try a scanner once it is returned to the shop but i want to get into the diag state to at least see what the codes are and try and fix this buggy!!!!
Old Jul 11, 2005 | 06:52 PM
camaroken's Avatar
Re: obd I question
thanks guys, got it figure out. thanks for all the help.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
