OBD I conversion
Old Feb 11, 2007 | 11:47 PM
mcssmostwanted's Avatar
OBD I conversion
i recently purchased a 95 obd I pcm for my camaro..
Are they just plug and play so to speak or is there any modification needed to use one? i read somthing about soldiering somthing to another thing? sorry about being vague!
thanks for any help...
dan
Old Feb 12, 2007 | 01:29 AM
sbs's Avatar
sbs
You need to change to the OBD1 knock sensor.
Old Feb 13, 2007 | 11:03 AM
is that the lil chip in the pcm?
Old Feb 13, 2007 | 09:38 PM
Ttt
Old Feb 14, 2007 | 11:54 PM
No. The knock sensor is screwed into the block drain plug on the passenger side of the block. The OBD-II sensor has a 100Kohm resistance. OBD-I has a 4.5Kohm resistance. You either have to swap the sensors, or add a resistor in the PCM. The "lil chip in the pcm" is the knock module and the same one is used for OBD-I and OBD-II.
Novo
Jun 14, 2016 02:58 AM
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Sep 6, 2015 03:10 PM
Aug 7, 2015 01:26 PM
