OBD conversion tranny fix?
Old Jun 10, 2004 | 01:06 PM
WS Sick's Avatar
I have a 97 with an OBD 1 conversion done to it. I thought before my rev limiter was set wrong, but when I looked the program over through tuner cat the rev limiter is set way higher than my problem occurs.
I have been fighting this for a while and have done everything from having the tranny looked over to replacing the secondary ign (and opti cleaning). I finally just gave up and started shifting sooner.
Anyway a guy thats into LT1s like myself said it may be because I have an OBD 1 computer and a 3000 stall, he said he heard here that that can cause problems.
My problem is a late shift, acts like it hits the rev limiter right before it shifts (6300 rpm). I cannot manually hold the gear past this either, but sometimes if I let it shift itself it revs past this a little and shifts fine (with a slight hesitation). Its kinda frustrating because I know I have a tenth or two of time if I get this fixed.
Any Ideas?
Old Jun 10, 2004 | 02:00 PM
steve40's Avatar
i'm having the same problem with my 97 as well.
i ended up calling precision industries yesterday for some help, terry was helpful and mentioned after your burnout, shut the car off and restart it. mine shifts fine on the street, just hits the limiter at the track no matter what bryan at pcmforless did, but it did get better.
i still have to get my tranny guy to look at it, since i scanned the run with datamaster.
let me know if you get it worked out, i'd like to know
Old Jun 10, 2004 | 04:37 PM
97Z-M6's Avatar
Re: OBD conversion tranny fix?
Any Ideas?
do you have tunercat if so you email a bin file and i can fix it for you. it works on 9 out 10 cars. if you email me a bin file tell me the origanal gear int he car. and who has done the tuning on it.
sorry to tell if bryans fix didnt do it. your tranny guy cant fix it. the only thing you can do is go back to obd2. its in the pcm not the tranny.
Old Jun 10, 2004 | 05:10 PM
steve40's Avatar
he is going to check over the tranny just to make sure that its nothing mechanical causing the problem, even though i can't see something being wrong with it and its only happening at the track
Old Jun 10, 2004 | 05:43 PM
97Z-M6's Avatar
steve check your email. need you to answer a question.
Old Jun 10, 2004 | 06:02 PM
steve40's Avatar
just answered it, thanks
Old Jun 10, 2004 | 06:09 PM
97Z-M6's Avatar
what gears do you have and what were the stock gears.
Old Jun 10, 2004 | 06:11 PM
steve40's Avatar
3.73's now, 3.23 where stock
Old Jun 10, 2004 | 06:49 PM
97Z-M6's Avatar
try that one and see if it works. and be sure and tell me what size stall you have.
Old Jun 11, 2004 | 08:13 AM
WS Sick's Avatar
I have my complete program, would you take a look at it, my car was an original 3.23 rear as well and now has 3.73s.
BigWil
Mar 29, 2015 12:24 PM
siguy
Nov 27, 2014 10:07 AM
MislMan
Jul 19, 2002 11:41 AM
