O2 Sensors Volts
Old Jan 1, 2010 | 05:15 PM
cleangene's Avatar
O2 Sensors Volts
I have been tuning on this car for about a year now and getting real close to having the tune to what I feel is right. My question is and may not be a problem but I need to ask. B1 O2 reads 70 to 900 volts, B2 reads 300 to 900 volts. B2 volts will not go lower than 300, is this a problem or not. The LTFT are almost 0 on both sides, I also use a W/B and it also reads a good AFR. Now I have changed O2's from one side to the other - no change, I also changed injectors from one side to other - no change. Checked and double checked header bolts for leak, exhaust for leaks - none. Should I worry about the volt difference.
Old Jan 1, 2010 | 07:16 PM
bobdec's Avatar
At what rpm ranges are the B2 O2 ranges at 300 mv ? Or is it always ? . At that time are the injector PW's slightly different ?? (B2 right side compared to left) . One thing to look at is a data log when you are in DFCO and the injectors PW= 0. At that time the O2's should both read below the 40-50 mv range. Since you swapped the injectors that eliminates a leaking one. If the B2 still reads high during DFCO (no fuel) then most likely the problem is electrical in the B2 circuit.
Old Jan 2, 2010 | 06:46 PM
cleangene's Avatar
found it, lose wire, thanks for the help.
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
zajones
Jul 30, 2015 02:18 PM
