no dyno tune close
Old Sep 24, 2005 | 12:37 PM
TTlord's Avatar
no dyno tune close
is a programmer a good substitue if there is not dyno tune close. i have a 94z and right now i have slp cai and loudmouth catback. i am looking at changing gears from stock to ??. i have to check the calculator on here to see what to do. any suggestions?
Old Sep 24, 2005 | 02:28 PM
Dnsean's Avatar
Re: no dyno tune close
3.73 are nice, u may need a new posi tho, and u will need a dyno tune, or hypertech to adjust your speedo because mine is way off.. also abs will not be functional with 3.73's if u dont want to do that, go for 3.42 then to keep abs, and i believe speedo wont be off i hear
i have also heard that dyno tuning may be better, not only is it a custom tune, but everything can get changed around for gears, shiftpoints n that sort of thing, plus you can get a before and after dyno sheet on ur hp/tq and all
Old Sep 24, 2005 | 02:53 PM
Alvin@pcmforless.com's Avatar
Where are you located at?
Old Sep 24, 2005 | 06:55 PM
TTlord's Avatar
i havent changed the gears yet, but am looking into it for a winter project. i am in iowa. my car has 3.42 gears stock. what i wanted to do is break into the 13s and runa above 100 in the 1/4. without any mods to the engine.
Old Sep 25, 2005 | 12:04 AM
RacingTiger04's Avatar
whats htis about the abs not working with 3.73??? i started getting an abs light soon after my gear install (mostly intermittent until the car sat for another 5 months then it stayed on).. never noticed any negative effects from it but the light went off tonight after i changed the fuel filter no idea what that would have to do with it *shrug*
Old Sep 26, 2005 | 02:46 PM
TTlord's Avatar
i talked to a friend that works at mopar and he said i shouldnt have to worry about the posi. he was going to look it up for me.
Old Sep 26, 2005 | 05:27 PM
2000GTP's Avatar
Throw on a nice pair of drag radials and I'm sure you'll see that 13 without tearing into the motor.
HarleyZ28
Oct 5, 2015 06:23 AM
Stay Puft
Middle Atlantic
Apr 19, 2015 11:39 AM
Jlo
Feb 3, 2015 09:41 PM
chevysam
Jan 16, 2015 07:45 PM
SC97TA
Sep 15, 2002 01:10 AM
