no dyno tune close
no dyno tune close
is a programmer a good substitue if there is not dyno tune close. i have a 94z and right now i have slp cai and loudmouth catback. i am looking at changing gears from stock to ??. i have to check the calculator on here to see what to do. any suggestions?
Re: no dyno tune close
3.73 are nice, u may need a new posi tho, and u will need a dyno tune, or hypertech to adjust your speedo because mine is way off.. also abs will not be functional with 3.73's if u dont want to do that, go for 3.42 then to keep abs, and i believe speedo wont be off i hear
i have also heard that dyno tuning may be better, not only is it a custom tune, but everything can get changed around for gears, shiftpoints n that sort of thing, plus you can get a before and after dyno sheet on ur hp/tq and all
i havent changed the gears yet, but am looking into it for a winter project. i am in iowa. my car has 3.42 gears stock. what i wanted to do is break into the 13s and runa above 100 in the 1/4. without any mods to the engine.
