no communication during scan
Old May 8, 2011 | 07:56 AM
Bails098's Avatar
Ive hooked up a snap on scanner i can enter in vin information it says trying to communicate it ends up failing. not sure what fuse to check if that may be the problem. Im not really sure where to start looking for problems. I looked to see if the wires were connected to the port everything looks normal there.
Old May 8, 2011 | 08:50 AM
Re: no communication during scan
Does the scanner require 12V power? If so, you need an external source, because there is no 12V pin in the OBD-I ALDL connector.
What is the brand and model of the scanner?
Old May 8, 2011 | 09:33 AM
Bails098's Avatar
The scanner does require 12v it has a connection for it on the side of the aldl connector.
I borrowed it from a friend it is a snap on brick
Old May 8, 2011 | 10:15 AM
And you hooked up 12V?
Old May 8, 2011 | 12:15 PM
Bails098's Avatar
yes the scanner wouldn't turn on without 12v. when it tried to communicate with the car it says failed to communicate make sure key is on. I did turn the key on.
Old May 8, 2011 | 12:20 PM
adam85's Avatar
Do you have the right key in the connector? I believe its a k9 key.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
jayblev95
Sep 26, 2015 09:44 PM
KYWes
Sep 26, 2015 08:49 AM
plattted
9
Sep 20, 2015 11:23 AM
tommalcolm
Sep 11, 2015 03:39 PM
