Need PROM burned for 93 T/A
Old Oct 25, 2002 | 12:48 PM
Trans AM 22502's Avatar
I'd like to start off by saying that I was smart enough to pick up alot of information about the various components of the car and how they operate in the various forums on this board. But when it comes to PCM/ECM/ECU or whatever else they are called, I have NO IDEA how to edit, control, etc. them.
So, I have a 93 T/A and (as I understand it) I need to have a PROM burned in order to make several changes to my car's various functions, particularly cooling.
I would like to have a PROM burned by someone on this board (I know someone does it) that allows me to use a 160* t-stat, electric WP come on @ 180, and my stock cooling fans come on at 190 and 215 respectively. (if the temp ever reaches that high) If a HIGHLY modified valvetrain will affect this in any way, I'll give you the necessary information to do that as well.
Old Oct 25, 2002 | 01:07 PM
385LT1's Avatar
www.pcmforless.com
Old Oct 25, 2002 | 01:17 PM
Actually, I've been there before and his last rule is its for 94 and newer vehicles only.
Old Oct 25, 2002 | 02:54 PM
385LT1's Avatar
Vehicles 1993 and older
Email to:
Chips@pcmforless.com
http://mywebpages.comcast.net/bherter/chips.html
Old Oct 25, 2002 | 05:17 PM
jgeorger's Avatar
Send email to jimperkins@attbi.com. He can do it, and is a good friend of mine.
How do you intend to make the ecm control the electric wp?
Joe
Old Oct 25, 2002 | 07:48 PM
Wilson's Avatar
If your just looking for minor changes like that I probably wouldn't pay someone too much to do it. It'll take like 1 minute to make those constant changes.
If you cant find anyone cheap then drop me a line and I can burn you a chip.
BTW- There arent any ECM controls to turn the WP pump on. Also, why would you want to do something like this?
Old Oct 26, 2002 | 02:59 AM
I apologize for the confusion on the WP statement. I should've mentioned that I heard that you could use a switch to turn the WP on even when the car wasn't running. Either way, I'll keep reading up on PCM/ECM/ECU;s hopefully the light will finally come on.
Bxlt1
Sep 29, 2015 03:18 PM
Schul365
Aug 22, 2015 10:00 AM
techstar
Aug 6, 2015 11:20 AM
4586
Dec 31, 2014 02:21 PM
