Need help Excessive spark??
I have been trying to tune my 94Z with tunercat. I created a spark advance curve based off a generic carb curve, the problem is I set max spark advance to 40* but according to datamaster it maxes out at 44-45* and does so from approx. 2200 to redline. I have set spark correction table vs. cool @ .1 , knock retard set for 220*, max spark advance is set to 40*, actual max timing (in table) is 38*.
where is the extra advance coming from??
Is there something I'm missing?
I just want to actually use spark tables I create
Re: Need help Excessive spark??
so could I just use the spark correction table and adjust to compesate for the extra timing??
This is a problem that's been around for a long time on the LT1's. I'm not sure where it comes from, but most tuners generally just accept that it's going to have 2-3 more degrees timing than the table says.
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
