Need help Excessive spark??
Old Sep 4, 2005 | 08:19 PM
Warlock1313's Avatar
Angry Need help Excessive spark??
I have been trying to tune my 94Z with tunercat. I created a spark advance curve based off a generic carb curve, the problem is I set max spark advance to 40* but according to datamaster it maxes out at 44-45* and does so from approx. 2200 to redline. I have set spark correction table vs. cool @ .1 , knock retard set for 220*, max spark advance is set to 40*, actual max timing (in table) is 38*.
where is the extra advance coming from??
Is there something I'm missing?
I just want to actually use spark tables I create
Old Sep 4, 2005 | 10:12 PM
Re: Need help Excessive spark??
ok so no one has any ideas?
Old Sep 4, 2005 | 10:39 PM
Usmuscl398's Avatar
iat sensor
Old Sep 4, 2005 | 10:55 PM
turbo_Z's Avatar
So just tune around it... take out 6 degrees in the high KPA ranges of 90-100. I also have experienced this and its only during WOT but I just took out timing till I see on my scanner what I want despite what the tables are set to.
Old Sep 5, 2005 | 12:07 AM
so could I just use the spark correction table and adjust to compesate for the extra timing??
Old Sep 5, 2005 | 05:28 PM
turbo_Z's Avatar
Well, you could but thats gonna pull timing in all KPA/MAP ranges and all you want is 90-100 KPA. The better solution is to just take it out of the main and extended spark advance tables.
Old Sep 6, 2005 | 04:58 PM
brutalbird's Avatar
Just wondering, is your spark reference angle set to something other than zero within the ECM Constants Table? Might cause this condition I think.
Old Sep 7, 2005 | 04:19 PM
engineermike's Avatar
This is a problem that's been around for a long time on the LT1's. I'm not sure where it comes from, but most tuners generally just accept that it's going to have 2-3 more degrees timing than the table says.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
