Need help choosing a way to go about tuning
Old Nov 9, 2008 | 09:14 PM
mrl510's Avatar
I have a 93 camaro z28. Im almost done building the motor. Its a 383 supercharged lt1. Im about to go crazy trying to decide on whether i want to convert my pcm and harness over to 94 with MAF and try to tune it or if I want to keep the 93 system And burn chips everytime i want to adjust anything. I know ill always be upgrading things so i dont know which way i need to go. I dont really know how to tune just yet but ill learn. Im willing to go either way. I just really want some input on what some of yall would do. I really dont know which way i should go, MAF or Speed density with the supercharger. Also if i decide to go with the 94 harness i wonder if i can just use the engine and trans harness an just connect the exsisting interior harness. Please help im getting to stressed out.
Old Nov 10, 2008 | 07:55 AM
bobdec's Avatar
I personally would learn on the '93 as is. It's going to take a lot of research, learning and some time to get it right. After that I would weigh the differences you will see going to a 'flashable' '94-95 MAF conversion and see you really need to. With a 383 supercharged setup you the SD tune may work out the best.
Old Nov 10, 2008 | 06:17 PM
jay_lt4's Avatar
pick up a moates ostrich and tunercats and you will be set to do real time tuning on your 93,, way better than flashing a 94-newer ecm
http://www.moates.net/product_info.p...roducts_id=169
Old Nov 10, 2008 | 06:30 PM
mrl510's Avatar
what else would i need besides a lap top? If i go this way?
Old Nov 10, 2008 | 08:54 PM
sreve's Avatar
nothing better than real time. check out www.tunercats.com for the software (cheap)
your biting off a big chunk with forced air as a first tune but you may
find a file to start you off at www.monodax.com
this is another good one for help with tunercats:
http://www.pacificp.com/forum/index.php
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
