Need '94 LT1 PCM ASAP
Old 10-08-2013, 09:08 PM
jjmoore81's Avatar
As the title says... Completed my most recent tunercats tune, finished loading, said complete, like it has so many times before. Only this time, when I went to start the engine and do a test run, it just sits and turns over. To add to the excitement, when I tried to plug back in again, I get an error that the PCM cannot connect. I need this fixed, or a replacement ASAP.
jjmoore81 is offline
Old 10-09-2013, 09:45 AM
bobdec's Avatar
Re: Need '94 LT1 PCM ASAP
Search on part number '16188051' there's a couple out on e-bay. Going price for a used one that will requires programming is $50-60.00. Try local junk yards. I have a spare that I keep around, programmed and ready to slap in. Assume you have a known good back up .bin file, if not let us know, what you need. An A4 requires F-body '94 .bin code, M6 can use F-body '94 or '95.
bobdec is offline
DirtyDaveW
12-01-2016 05:37 PM
willismoons
02-14-2015 08:42 PM
Brake_L8
01-20-2015 09:44 AM
ro2207
12-04-2014 06:18 PM
Hot Rod Hawk
08-30-2002 10:12 PM
Quick Reply: Need '94 LT1 PCM ASAP
