Mat ?
Old Feb 28, 2007 | 11:23 AM
2xLS1's Avatar
Mat ?
Yes, MAT, not MAF. I see this referenced in 96/97 TC OBD2 cals. What does it stand for?
Old Feb 28, 2007 | 11:38 AM
VinceTrifecta's Avatar
In what context is it referenced? I opened up my TC OBD2 editor and I don't immediately see any tables or terms that used that acronym.
Old Feb 28, 2007 | 11:56 AM
2xLS1's Avatar
97 Camaro cal.
Constants>Fuel Paramaters
MAT Modification to MAF Enable Temp
MAT Modification to MAF Disable Temp
Constants>Emissions Parameters
EGR Enable Coolant Temp (High Startup MAT)
ERG Enable Coolant Temp (Low Startup MAT)
I'm guessing it is a temp of some kind.
Old Feb 28, 2007 | 12:06 PM
I see it now, thanks for the pointer.
I did a search on the web for "MAT sensor" and somebody's page on their C5 came up, talking about relocating the MAT (Manifold Air Temperature). From the description, it sounds like they are referring to what is also called the IAT (Intake Air Temperature) sensor.
It is interesting that TC's software makes a differentiation between the MAT and the IAT. You might try sending him mail about it, but my guess is these terms are either used interchangibly or the PCM has some algorithm for determining the manifold air temperature based on other sensor inputs.
Old Feb 28, 2007 | 12:19 PM
2xLS1's Avatar
Found another one.
Tables>Fuel Tables
MAT Modifier to MAF vs MAT
I thought the same thing, just another term for IAT, something like Manifold Air Temp, but like you said in the same Fuel Tables menu, there is also a reference to IAT.
AviatorDave
Dec 19, 2016 06:35 PM
Trimix
Parts Wanted
Aug 15, 2015 10:46 AM
Jun 5, 2015 10:16 AM
May 8, 2015 11:30 AM
Mar 13, 2015 07:15 AM
