MALF 16: Lo-Res Fail
Old Jul 22, 2004 | 12:37 PM
Valkyn71's Avatar
Can anyone tell me what this code means?
Also to avoid stupid questions like this, can anyone tell me where i can find a database of all the codes and their meanings?
Thanks!
Old Jul 22, 2004 | 12:40 PM
TigerWoodsJr's Avatar
Re: MALF 16: Lo-Res Fail
I know the haynes manual has a list of all the codes in it, not sure where to find them online. I think that res is something around the ign module/coil or something like that.
Old Jul 22, 2004 | 01:21 PM
Thanks!
That is a low resolution code from the optispark. If your engine still runs, it was an intermittent thing, because it will not continue to run with the problem occurring. Your opti may be getting ready to go or you might want to check the harness connection for corrosion, especially on the opti end.
There is a link with a full listing of all the diagnostic codes on the right hand side of my Tech Page.
Old Jul 22, 2004 | 02:06 PM
Valkyn71's Avatar
Could this code have anything to do with me "chipping" the plastic around the opti end of the wiring harness, and me running mid 15's at the track with my mods?
And yet again, shoebox
I am humbled in your wisdom!
Old Jul 22, 2004 | 10:35 PM
If there is any way the terminals might get together, then it could be a potential issue or if any corrosion is present.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
Boss002
Jul 24, 2015 10:47 AM
Deadcarny
Dec 17, 2002 04:50 PM
copper88iroc
3rd Gen / L98 Engine Tech
Dec 13, 2002 04:56 PM
