MAF delete?
Old Oct 21, 2008 | 08:40 PM
19z28camaro02's Avatar
Lightbulb MAF delete?
If I send the PCM to be re-tuned(ex. MadZ28) can I have the MAF tuned out even though it is a 96? Do I gain or lose anything by doing this?
Old Oct 21, 2008 | 08:45 PM
cammed SS's Avatar
Thats not possible. Car wont run without MAF. You can descreen it but that about it.
Old Oct 21, 2008 | 08:47 PM
blown94's Avatar
i dont think speed density tune uses a MAF, and you can choose speed density in OBDI pcm but I dont know about OBDII
Old Oct 21, 2008 | 08:51 PM
http://www.madtuner.com/order.php It has a speed density option but i dont know if its just for 93 cars. I want to switch mine over to not have the MAF and still be on OBDII. Any help is appreciated here.
Old Oct 24, 2008 | 10:24 PM
dookie454's Avatar
Unplug the MAF and your running in Speed Density mode, check engine light will come on until you tell the PCM to ignore the MAF. That's it.
If the car doesnt run with the MAF unplugged then you either have something wrong or you modified the engine (cam swap) to the point where the base SD calibration is no longer valid.
A good test to see how far off your base tune is just unplug the MAF and see how it runs. A better test would be disconnect the battery for awhile and unpug the MAF then reconnect the battery then start it up. This way the PCM losses all the BLM's and runs purely off the SD tables, once Closed loop sets in it will fix up some minor errors in the base tune but it can only adjust a certain amount.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
