LT1 A4 shift point programmaing survey
whats everyones mods and shift points, i need some suggestions so i wanna see what you guys are running to see what works and what doesnt with what combos.
Re: LT1 A4 shift point programmaing survey
when you say 6100 and 5900 is that the value you have input in the fuel cut off area or is that what you have interpulated based off your selected mph for shifts. what are your mph for shifts and kickdowns also. and did your rpm take into acct the 3-400 shift time buffer and what are some good inputs for shift time. .750 sec or what?
My rev limiter or fuel cut off is set at 6300 RPM, 1 to 2 is set at 36 MPH 2 to 3 is at 70MPH for upshift. Downshifting from 3 to 2 67 MPH and from 2 to 1 31 MPH. My shift times are set around .750
jb4xx
Feb 2, 2015 10:00 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
