losing 1st and 4th after tune
Old Mar 19, 2014 | 05:24 PM
vamvwj's Avatar
Exclamation losing 1st and 4th after tune
Have a 95 z28 with 4l60e a4... Never had any issue with transmission losing 1 and 4 gears till I was tuned.. I have tried replacing the 1-2 and 3-4 solenoids no change.. I can start off drive up through all 4 gears and stop 2times and on 3rd start when it shifts goes directly to 3rd gear (limp mode)... Tune was to set f/a ratios for my cold air intake.. Shaved heads.. Advanced timing for 93+ octane.. Removed a.i.r.. A/C... Any traction control deleted (to best of my knowledge it never had TCS)... And tcc lockup in 2nd and 3rd gears.. Anyone ever had similar issue? I have taken the car to Chevy dealership and no codes show up. I have a free retune with this guy but want to make sure the issue before I waste the retune.. Any help would be much appreciated
Old Mar 20, 2014 | 08:28 AM
Re: losing 1st and 4th after tune
Did the Chevy dealer realize he needed an OBD-1 scanner with the correct adapter plug. There are a number of transmission codes that do not turn on the SES light.
Old Mar 20, 2014 | 08:47 AM
vamvwj's Avatar
I assume so.. They said they knew they had to have the adapter but I think I'm going to try another Chevy dealership and get a second opinion
Old Mar 20, 2014 | 08:54 AM
Jon eds's Avatar
Is there anyway to check the codes with a paperclip like the regular obd1 ports? If so what pins need to be jumped?
Sent from my SCH-I545 using Tapatalk
Old Mar 20, 2014 | 11:07 AM
moparman's Avatar
'93 was the last year the pins could be shorted to read the codes. '94 and up require a real code reader or scan tool.
Old Mar 21, 2014 | 11:04 AM
Jon eds's Avatar
OK so I took it back to a different dealership and watched them read the codes nothing.. Even took one of the service guys for a ride to show exactly what it does.. Lost 1 and 4 and he connected the scanner again while car was running still no codes thrown
Old Mar 21, 2014 | 03:43 PM
Then we may want to move this to "drivetrain".
Let me know if you want it moved.
Old Mar 21, 2014 | 07:40 PM
Jon eds's Avatar
If the following post is not possible please move it for me.. Thank u
Old Mar 21, 2014 | 07:43 PM
Jon eds's Avatar
OK so tonight I unplugged the PCM and cleaned the maf sensor.. Put it all back together and everything worked fine until I was stopped and floored it to see what would happen... I must have started and stopped 20 times befote nailing the throttle.. The car didn't seem to want to shift outta 1st but finally did but very high rpm.. And then went back to 3rd immediately.. Thus I'm back into limp mode again.. Is it possible that the tune has too high rpms for 1st causing it to go into limp mode?
Old May 20, 2014 | 07:15 AM
Jon eds's Avatar
So I have bought a new PCM and the stock programming doesn't cause limp mode.. What could have happened in the tune to cause this?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BLK1997Z28
May 7, 2015 03:01 PM
simple
Aug 2, 2002 03:30 PM
