Knock Retard??? Help
Old May 5, 2012 | 11:00 AM
V8 LifeStyle's Avatar
Im a little confused here. (Im guessing I should get a new knock sensor? or getting this product from DEI I belive that goes wrapped around the knock sensor to block out any exterior false knock) I have heads/cam/TB/ Roller Rockers/ LT4 knock module/LTs x pipe/ maganaflow mufflers dummped at the rear by the bumper. I logged my car lastnight at the track when I was doing some passes. First run no knock retard, second run knock retard as high as 6 degrees in the 5000 rpm then like 4 and 2 from 3k-45k (thats thru first gear) second gear no knock retard. did another pass after backing off timing same thing keeps happeing . I am running 93 Unless Shell is ripping people off lol.
What could be the problem? Thanks guys
Old May 5, 2012 | 11:05 AM
Re: Knock Retard??? Help
srry the product is not from DEI its from Dynamat
Old May 5, 2012 | 03:59 PM
bobdec's Avatar
Is knock count incrementing when the PCM is pulling timing ? If not could be burst knock or the PCM remembering old knock conditions and pulling timing to avoid it. In MOST instances if knock stays after pulling 5-8 degrees of timing at the RPM/MAP conditions that fail (as a test) is not real pre-detonation. Also if knock count bumps under low to now loads (low Kpa) it's not real. It gets tough to insure it's pre-detonation or just plain something vibrating.
Old May 6, 2012 | 12:40 PM
Yea i just checked and knock count increased
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
