knock counts on startup?
Old Nov 26, 2003 | 10:31 AM
ryaskovic's Avatar
For those with scan tools (I use Datamaster), what kind of knock counts to you get on a cold start-up? On my 7k mile forged-piston 383 LT1 I'm seeing 4000-12000 knock counts (it varies) on a cold start, through the first 15-20 seconds or so of engine runtime. On a hot start, knock counts are more like what I'd like to see on all starts (1500 area).
Note that a "cold start" for me in Florida really isn't that cold (weather is typically 70-93degrees) for when I've logged this data.
Thanks,
RobY
95Z28
Old Jan 21, 2004 | 03:34 PM
ryaskovic's Avatar
anyone?
Old Jan 21, 2004 | 05:26 PM
DOOM Master's Avatar
I've seen this before on other engines, both strokers and non. I wouldn't worry about it, it's probably due to cold rockers or something making more noise than normal.
Old Jan 22, 2004 | 09:06 PM
SABLT194's Avatar
I've seen this on mine very often. I think mine is caused by my Street Twin flywheel teeth making so much noise during starter engagement. Who knows????
Steve
Old Jan 25, 2004 | 09:03 PM
philcam01's Avatar
I also have alot of knock counts on start up and high rpm . I have LT1 edit and can't figure out how to reduce the amount it sees .
Old Jan 27, 2004 | 07:57 PM
RCF925's Avatar
If your running forged pistons which may have a slightly wider piston to cylinder wall clearance than stock depending on who put the motor together you will get some piston slap on cold startup for a couple of minutes which is normal.
Old Feb 1, 2004 | 05:24 AM
MentalCaseOne's Avatar
Stock here. 63 counts on start up.
Marvin
Nayr
Mar 3, 2023 08:34 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
