Connecting My Laptop to my PCM
Old Jan 31, 2004 | 03:07 PM
Blown 96 WS-6's Avatar
Okay, I just received my copy of DataMaster and my ALDL Adapter and Cable.
I'm a little pissed that I read no where that I needed to buy a "standard" serial cable I thought it would come ready to go. No where on the web site or when I spoke to TTS did they mention that.
Anyway, I will go buy one but I can also find no mention of the proper procedure for connecting the laptop to the PCM. I would assume there should be a "proper" way to do this so that you don't run the risk of damaging either the PCM or the laptop or am I over thinking this?
Do I have the laptop running and DataMaster running and plug in? Should the car be running yet or not?
I figured the car should be off and the laptop can be on but I don't know whether DataMaster should be running yet or just what.
Someone please give me an answer as I'm a bit computer challenged
Oh, also, do I assume that you can't just go for a ride and watch the readings? It looks as though you always have to record then you have to replay it to see what's going on. That is also confusing me a bit.
TIA
Old Jan 31, 2004 | 08:07 PM
Tair's Avatar
Leave the car off, leave the laptop off. Plug in the cable FIRST. Then turn on the car and laptop. Generally just don't plug/unplug any cables hooked up to your computer or car while power is going through them.
Old Feb 1, 2004 | 09:27 AM
Okay, that makes sense. Thanks!
sherwinZ28
11
Aug 15, 2015 05:38 PM
88IROC_Z
Jul 22, 2015 11:38 PM
whitehooptie
Jul 22, 2015 10:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
mrwz28
Jul 8, 2015 09:11 PM
