key cylinder problem
Old May 28, 2007 | 11:11 PM
Daniel6718's Avatar
i need a new key dylinder, the security light is on all the time and every couple days it wont start...my question is do i need new keys? or new module under the dash? or just a key cylinder? and it matched to my keys?
basically need to know if there is a resistor in the key cylinder and the key or jsut the key matched to under the dash....
also if anyone knows what they run that would be nice also...
Old May 29, 2007 | 06:28 AM
Guest47904's Avatar
Guest
The resistance is in the key. Called a key pellet. The switch has contacts that use the resistance to allow the theft detterent module to engage the starter circuit.
Rather than go through the replacement of the switch, why don't you simply bypass the sensor for the key with the same value resistor and be done with the problem.
Schematic here:
http://shbox.com/1/pass_key.jpg
Bypass here:
http://shbox.com/1/vats_bypass.jpg
Remember if you want to bypass the switch you do not need to cut the wires. Just unplug the orange overwrapped wires and put the proper value resistor in the connector going to the TDM.
Old May 29, 2007 | 10:58 AM
Daniel6718's Avatar
ok, i can try that...id rather that not be a perminate fix but since my a/c just went out and i need new tires i think ill try it for a few months maybe make it through the summer...
if i do decide to fix it with a new cylinder what would i have to do?
Old May 31, 2007 | 05:32 AM
Guest47904's Avatar
Guest
The steering column has to come out. Shoebox has the procedure for it.
Old Jun 3, 2007 | 06:58 AM
smoknta's Avatar
You could just have a worn out key. Have you tried other keys?
liamcg97
Nov 25, 2019 05:55 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
tds1213
Nov 27, 2014 12:55 PM
