Just got MadZ tune, but.....
just recieved my madz28 tune
, put it in, went to the track, then my opti went
. now my engine light is coming on, used hypertech scanner and it's throwing distributor codes(obvious opti problem) but also, it's now showing "pcm memory"code. what does this code mean??
Re: Just got MadZ tune, but.....
Hmmm....
so it was fine for a while (no codes) then you got this?
Did you try switching to your stock PCM to see if the codes are the same? I am suspecting a bad ground (provided it ran fine before), but if you also notice some driveability problems, then it may be the opti.
the thing is, is that i got the tune, went to the track and was running slower than usual(no engine light was on, so i'm assuming no codes were being thrown). i'm sure it wasn't specifically due to the tune(thinking opti), because my buddy that got the same tune was running 2mph faster in the 1/4(just from the tune), we swapped our computers, and he was running same times and mph with his comp, and i was running the same crap as i was with mine. my car stalled a couple times and had rough idle on and off once i got the tuned comp, and i think that the opti just started going at that time, but nothing had to do w/ the tune. so who knows, i guess i'll just have to wait 'til next season to figure it out now that the car's going to sleep for the winter tomorrow. if anyone else has any opinions, i would be happy to hear them.
btw, thank you Ion, the tune you gave my buddy worked wonders (2mph in the 1/4), and i'm sure mine did the same, just can't tell all that much w/ a bad opti. just bad timing.
ok, here we go again, now the scan isn't showing opti spark codes, or the pcm memory code, now it's showing the following: P0200 ( injector control circuit ), P0332 ( knock sensor circuit low voltage bank 2 ), P1222 ( injector control circuit intermittent )
WHAT IS WRONG WITH MY CAR???
mine was doing the same thing kinda.... i kept getting different codes and then i started to blow fuses. check your grounds.... this is thebest advice i can give because thats the advice i was given... im still in the process of finding my problem
Just a thought, I was getting a lot of weird codes, then came to find out the alternator was not giving enough voltage, which was confusing the hell out of the computer. Just a thought, check the voltage at the battery before starting and after to see where you are at.
Aug 24, 2015 06:41 AM
