Idle PE mode guys inside
Old Feb 6, 2005 | 07:22 PM
  #16
turbo_Z's Avatar
Re: Idle PE mode guys inside
Originally Posted by 97Z-M6
turbo........ which def file do you have, i have the lastest one. def. ver. bj
Just checked and its the BJ file. I emailed it to a few guys in this thread.. you are one of them. I suspect TC didnt rename the file they sent to me. It was basically the same new def. file that everybody was asking for late last year with the integrator min/max capability but this one just has a few switches unlocked so you can turn of the DTC.
Old Feb 6, 2005 | 07:23 PM
  #17
Highlander's Avatar
Yeah i noticed it has some extra DTCs which is really nice
Old Feb 6, 2005 | 07:40 PM
  #18
97Z-M6's Avatar
yep the O2 dtc in the switch table is nice.
ive had it for a while.
Old Feb 6, 2005 | 08:04 PM
  #19
bunker's Avatar
Yes I really need this DEF file, please someone email it to me:
bunker@telus.net
I used the STFT limits and LTFT limits along with altering the MAF table down low to run leaner at idle but I get all sort of codes.
I also made it run richer while driving in certain areas to help smooth the engine out, more fuel helps build dynamic compression down low, so I get a right o2 rich code, the thing always took lots of fuel out of the right, I'm done everything from getting new heads, new fuel injectors, new o2's you name it its been through it, just seems like its the intake design that with big cams the right side either gets more fuel or something, whatever I looked at the left side and saw the minimum STFT and LTFT the intergrators go to on that side and set those as limits for the right side, car runs 10X better so who knows what is going on, I think one cyclinder from 1500-2200rpm gets more fuel then needed on that side, so the PCM kills fuel on all cyclinders on that side making the car run like crap, setting these boundries made a night and day difference, although a bandaid, its all thats left now LOL.
Anywho, wants to upload me that DEF file so I don't keep throwing codes and then going to open loop
Old Feb 6, 2005 | 08:34 PM
  #20
97Z-M6's Avatar
bunker i sent it
Old Feb 6, 2005 | 08:36 PM
  #21
turbo_Z's Avatar
bunker@telus.net
You will still go into open loop if you idle for too long in closed loop even with the new def. file. I believe the PCM is still alerted by the lean condition... it just doesnt throw the code.
Old Feb 6, 2005 | 11:01 PM
  #22
Capt'n Two Rotors's Avatar
Noob here can I get it too? yellowsupra88@yahoo.com
Troy
Old Feb 7, 2005 | 02:07 AM
  #23
bunker's Avatar
Hmm... well hey anyways I got the DEF file but I don't see any of the new codes, perhaps I got an older one?
Please resend.
Old Feb 8, 2005 | 10:57 AM
  #24
bunker's Avatar
Some please send me the file:
bunker@telus.net
I got one from a member here but it didn't have the codes we are talking about, perhaps its a wrong one.
Old Feb 8, 2005 | 06:48 PM
  #25
mourningyou's Avatar
could you send it to me please? thanks
mourningyou@gmail.com
Old Feb 9, 2005 | 06:52 PM
  #26
97Z-M6's Avatar
bunker sent you a link to it
Old Feb 9, 2005 | 08:51 PM
  #27
turbo_Z's Avatar
If you guys want it then, like I stated before, PM me because I will not make it publically available for just anybody to get a hold of.
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
