IAC motor just need time to learn?
Old Jan 19, 2004 | 05:31 PM
wytblur's Avatar
My new 383 will Idle fine just sitting but when i'm on the road and push in the clutch to coast or roll to a stop the car idles lowww, then dies. I have a BBK 58mm TB and made the modification where you drill the hole for the iac...did this help or hurt? i'm not sure, i did read in my haynes manual (it was good for something!) that when disconnected the ecm needs time to relearn the idle speed of the engine...should i not worry about it and give it time, or look and check something else?
Old Jan 20, 2004 | 05:45 AM
This belongs on "Computer...", or "LT1 Tech".
There is a "learn" precedure for baselining the IAC target counts. Shoebox has it on his website. But that doesn't sound like the problem you are having. IAC counts on over-run (coasting on closed throttle) is controlled by a seperate table. Perhaps your prgammer needs to make adjustments to that table.
Moving to "Computer...."
Old Jan 22, 2004 | 01:58 AM
Chris 94Z A4's Avatar
Sounds like a vacuum leak to me.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
willismoons
Feb 14, 2015 08:42 PM
Z28countrymama
Jan 22, 2015 02:50 AM
