i need to read my codes but my car is OBD-I
Old Jul 26, 2007 | 12:58 PM
jamilz28's Avatar
how could i check the codes on an OBD-I car?
Old Jul 26, 2007 | 02:15 PM
moparman's Avatar
You need an OBDI code reader or scan tool. Or the appropriate software and cables for a pc or laptop.
Old Jul 26, 2007 | 02:48 PM
jamilz28's Avatar
what is a cheap on and where can i get it?
Old Jul 26, 2007 | 05:40 PM
OBD-I Software:
TTS DataMaster (free download, 20 free uses):
http://www.ttspowersystems.com/
FreeScan (free):
http://www.andywhittaker.com/
pcmcomm (bundled with LT1_Edit software):
http://www.carputing.com/
EFILive V4:
http://store.efilive.com/overview_obdi.aspx
Cable available from:
http://www.akmcables.com/
Scan data interpretation:
http://members.aol.com/InjuneerZZ/ScanMast.htm
For a hardware scanner, Auto Xray made a hand-held scanner that was fairly popular. You can find them used for less than $100. Just be sure NOT to get the Actron "code reader" for $30. Its just a switch that shorts the pins on the ALDL connector, and will only work through the 1993 model year. The box will say it works on your 94, but it won't.
Old Jul 28, 2007 | 10:17 AM
3DFORMULA's Avatar
My Haynes manual says that you can put a jumper wire from the Diagnostics test port to the ground port, then turn key to on position and get codes. I did try this myself but could not get the codes, it just turned my fans on.
I don't mean to butt in here but I'm having problems also with my '94 OBD1.
Old Jul 28, 2007 | 11:20 AM
moparman's Avatar
Using the jumper only works on '93 and backwards. '94 and up require the right tools.
Old Jul 28, 2007 | 02:53 PM
Originally Posted by 3DFORMULA
... I did try this myself but could not get the codes, it just turned my fans on.
...and that's all it will do...
Old Jul 28, 2007 | 07:57 PM
3DFORMULA's Avatar
Thank you
Noenav
Mar 1, 2019 07:38 AM
Dec 1, 2014 08:08 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
Brent94Z
Mar 21, 2002 04:44 PM
