I have a idle problem, I recoreded part of my screen with tts running
Old Sep 21, 2007 | 07:00 PM
Projectcam94's Avatar
Question I have a idle problem, I recoreded part of my screen with tts running
I have a idle problem .. Idle goes up and down and i havent being able to diagnose the problem with it.. Im new with this program tts.. So im asking you all to help me out if you can.. TAke a look at this vid and tell me what you see wrong..
http://www.youtube.com/watch?v=pVghKf0KV8U
Old Sep 21, 2007 | 08:27 PM
2xLS1's Avatar
Your IACs at 0 and then going from the high 20s to 0 is your problem. Look for air entering the engine after the throttle body like a vacuum leak.
Old Sep 24, 2007 | 04:28 PM
You are right.. I took it to a mechanic today and he found a big EGR valve leak, and 2 tb leaks. One is on the gasket and one on where the gas cables hook up to.. He used a smoke machine to find them...
Hes going to fix them today and the car will be out tomorrow
Old Sep 28, 2007 | 07:37 PM
Problem Fixed... It was the optispark.. He fixed the leaks and was abile to diagnose the car correctly and found out the opti was bad.. ITs all greasy... He says i have a intake leak.. Im putting in a new intake soon so he will fix it then
Britbilly
Jan 7, 2015 08:49 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Absolute Z28
Jul 19, 2002 02:21 PM
