how much to alter MAF tables by for descreened MAF?
Old Sep 1, 2003 | 04:36 PM
bunker's Avatar
Just wondering, I descreened & polished my MAF, I want to find out how much to adjust the maf tables by, thanx guys.
Old Oct 3, 2003 | 01:17 PM
TwEaKeDSS's Avatar
ttt
Old Oct 4, 2003 | 12:28 AM
95Blackhawk's Avatar
At least you understand you will have to modify your MAF tables because of the descreening.
How much will depend upon the car. mine varies from 12% taken out in the low end to 7% added on the upper end. Inbetween, a no variance area was present.
Ben
Old Nov 1, 2003 | 11:59 AM
therealmagyver's Avatar
I wanted to port the maf but not descreen, but that doesn't seem to be possible after I opened up the units. If I descreened I would need to tune?
Old Nov 2, 2003 | 10:51 AM
Possibly. Personally, I would not screw with this part of your car. there are other areas that you can work on to "maybe" give you performance enhancement without the headaches of messing with a MAF - a very sensitive sensor.
Ben
Old Nov 3, 2003 | 04:36 AM
Tech's Avatar
Put the screen back in. That honey comb screen is designed to spread the incoming turbulant air more equally across the sensor, thus giving a more accurate reading of the incoming air.
Double aught
Oct 2, 2015 11:29 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
