How do you tune for 30# SVO f.i. with tunercat
Originally posted by DOOM Master
Under ECM constants, the second constant should be Injector Flow Rate. Type in the number for the SVOs lbs/HR flow rate, save, upload the file to the car.
Thats the part I already knew. Isn't there another table you're suppose to modify? Also whats the formula to compensate for the lower fuel pressure that SVO's are calibrated for? I know you're suppose to set them around 31.5 lbs but wanted to do it with the formula.
The formula is the Ford SVO pound rating times the square root of (GM fuel psi / Ford fuel psi), which I believe is either (43 / 39.5) or (43.5 / 39). So it's either 31.1 or 31.7.
I think someone else knows for sure.
You'll also want to change the injector offsets. Do a search in this forum for a link to a table. The Somewhere between the 24# and 42# table should work well. No one seems to have found Ford's rating for the 30#.
I set the high slope on the FR 30# injectors to 31.5 , to start, but remember, the constant is not set in stone. On fords, I set the them for 28 and 31.5, for high and low slope, to give you an idea. Good luck!
jim
jim
Try putting these #'s in the "injector offset vs. Battery voltage table" from this site.
http://carprogrammer.com/Z28/PCM/Injector/injectors.htm
Brian
Brian
Are those offsets correct? They seem to be way off of what the factory settings are. Even the table for GM Multec inj. are way off of what the ecm has set. Also, I dont believe tunercat allows you to factor in a number after the decimal point; it rounds to the nearest whole number.
Originally posted by drop top steve
Try mulitpling the oem offsets by 1.4 for 30lb svo's
Thanks for the input. Those numbers seem alot more logical then the ones on the fi sight. How did you determine to multiply by 1.4? Is there an equation to figure this out?
Steve,
Steve,
I'm still working with vemaster to try and get 128 in all cells, getting closer.
Or are you changing the offsets based on what you see from VEMaster or something?
Steve,
How about some input on straightening up the blm's; that was going to be my next project
Steve,
I got two short wot runs, both times it hit cell 18 and a blm of 128
It appears VEmaster worked for me. I've just spent the last four hours comparing .lt1 files I have collected on the web
kind of interesting how pro tuners change things. I've put together a tune I want to try tomorrow if it's not raining. I've got a dyno day on the 18th, so I would like to have everything ready for that. I'm hoping for a good turnout for the dynoruns, I would like to talk to someone who has played with PE. If anyone needs a copy of vemaster, I have the newest ver, email me and I'll send you a copy (freeware)
Originally posted by Dan K
So modifying the VE tables in your car is working to bring the blm's in check?
