How do I learn to tune?
Old Nov 4, 2005 | 11:31 AM
Vicious95Z28's Avatar
I have been interested in this for some time now. I am aware of the lt1 edit and Tunercat software. How difficult is learning to tune and how detailed are these two softwares or is there another type that would be better?
thanx
Vicious
Old Nov 4, 2005 | 01:46 PM
cpt_bimes's Avatar
Re: How do I learn to tune?
From what i've gathered...HPTuners is novice friendly i think...I'm pretty sure with Edit you have to know what alot of parameters mean.
Old Nov 4, 2005 | 01:55 PM
LWillmann's Avatar
Tunercat would be less expensive and probably easier to use getting started.
I'm told the help file with it is very good as well.
Old Nov 5, 2005 | 07:45 PM
Thanx Guys,
Would it be a good idea to get a scanmaster first?
Old Nov 8, 2005 | 07:12 PM
Silver's Avatar
start here: http://para.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
you need to know what everything hooked to the pcm does before you begin to experiment. self-explanatory to a certain extent after that.
Old Nov 9, 2005 | 01:15 PM
bunker's Avatar
You don't, you give up. LOL
Old Nov 13, 2005 | 09:56 PM
Doc99SS's Avatar
Tuning a PCM is not very difficult. However, people forget that you must know what the engine is doing in order to determine what to tune or change for the better.
Therefore, not only would you be buying tuner software, but also a scanner. The scanner is critical in knowing what the engine is doing and figuring out what it needs to make more horsepower, or to idle more smoothly, or improve drivibility.
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
