How Do I Check BLM'S
Old May 1, 2003 | 06:41 PM
Rico's Avatar
I'm a little new at this but how do I check my BLM's
...Rich
Old May 1, 2003 | 06:58 PM
Dan K's Avatar
With a scan tool such as Datamaster, Freescan, a scanmaster, etc...
Got one?
Old May 2, 2003 | 07:05 AM
Rico's Avatar
No, where can I get one of these.
Thanks for your help
Old May 2, 2003 | 06:50 PM
Another Red Z's Avatar
You can get the scanmaster here http://www.tbyrnemotorsports.com/lt1catalog.html under ingition . Datamaster here http://www.ttspowersystems.com/dm_dload.htm this is only good for 94-95 cars . You can buy his cable or get one here www.akmcables.com. Freescan is here http://www.andywhittaker.com/ecu/ecu_software.htm hope all this helps.
Old May 4, 2003 | 12:31 PM
Re: How Do I Check BLM'S
...Rich
What year is your car? That will determine what scan hardware and/or software works on it.
Use the "signature" field to insure that the improtant info about your car is always posted when you ask a tech question.... that way people will be able to give you a more accurate answer.
Old May 4, 2003 | 07:26 PM
ablackcamaro's Avatar
I've tried FreeScan to read the BLM's on my car ('95 Formula, stock) and it says it only works on Lotus's or a similar message. I can get it to read the BLM's for the current cell, but I don't want to have to drive through each and every cell. Is there any program where you can read the BLM's as if they were DTC's-just by turning on the ignition and hitting a "read BLM" button?
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
