How accurate is the stock tach?
Old Nov 24, 2010 | 07:37 PM
TT350's Avatar
96 T/A 100k miles bone stock.
Leaving it in drive the tack is showing 6500 shift points.
This can’t be right, can it?
Old Nov 24, 2010 | 10:16 PM
Re: How accurate is the stock tach?
Check it with a datalog. Tachs vary by individual car.
Old Nov 24, 2010 | 11:25 PM
dookie454's Avatar
In your opinion, does it seem to stop pulling near 6000-6500rpm? A stock motor usually runs out of steam past 5500rpm for sure.
Old Nov 25, 2010 | 11:04 AM
TT350's Avatar
It pulls good all the way to the shift points.
No complaints with the performance, I just know
that the stock cam is not much good past 5500.
I knew it was off, just wondered if it was a common thing with these cars.
I may send it off and have it calibrated.
Old Nov 25, 2010 | 02:38 PM
Typically, they read 100-200rpm higher than actual enigne speed, and in extreme cases 400rpm. Since the stock rev limiter is set for a bit over 5,800rpm, yours would have to be reading 700rpm high if the car is truly "bone stock". Never saw one off that far.
mr28
Apr 20, 2016 05:44 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
mr28
Nov 23, 2014 11:11 AM
