"HELP" tried to program ECM and now car wont run
Old Aug 18, 2005 | 07:44 PM
SUTTERERMAN85's Avatar
i tired to program ECM and now my car does nothing. when i hook up data master it says no "pcm sync" how do i get a program back on it?? do i have to buy another computer??
Old Aug 18, 2005 | 09:42 PM
madwolf's Avatar
Re: "HELP" tried to program ECM and now car wont run
If you were reading it, then pull the negative battery terminal for a minute or two and you're all set. If you were programming it, then the PCM is corrupted and will require repair. I offer this service if you are interested. (you can check it out here: http://www.madz28.com/repair.php)
Old Aug 19, 2005 | 09:23 AM
thanks that worked. i got lucky i guess. tunercat says "PCM invaild response"
why is this? datamaster works fine??? you are the master so i guess/hope that you can help me out. really appericate it.
thanks
nick
97SSdude
Dec 31, 2014 07:43 PM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
