help! no fire from coil
Old Jan 20, 2005 | 06:03 PM
1970z28's Avatar
Unhappy help! no fire from coil
well to start with i just finished a v-6 to a lt1 conversion. when i tried to start engine turns over good but no fire from coil. getting power to the coil. also i swapped the entire coil and module from another camaro and it fired right up. put his on my car still no fire. this is a 94 camaro, 94 wire harness computer sent to ion and had programed disabled vats, air, egr, and speed limiter. i am getting about 14 volts from the harness that hooks to the coil. and the same on the module. could someone please please help me. like to hear it run. i have left the rad. and fans, maf, off right now until i hear the heart beat.
Old Jan 20, 2005 | 06:13 PM
Capt'n Two Rotors's Avatar
Re: help! no fire from coil
Are you getting a signal to the neg side of the coil? It should pulse a test light in you hook the clamp of the test light to the positve on the battery poke the neg wire going to the coil. Where ya at in AL?
Old Jan 20, 2005 | 06:17 PM
1970z28's Avatar
just came in the house to post this. i will check that tomorrow. empire al. between jasper and birmingham.
Old Jan 20, 2005 | 08:31 PM
1970z28's Avatar
anybody else. really need help.
Old Jan 22, 2005 | 08:33 AM
1970z28's Avatar
found the problem the opti was bad, now the injectors want send no fuel to the cyl. can manualy run power to them and they pulse.
KYWes
Jun 14, 2022 06:52 AM
Jlo
Jul 29, 2015 03:52 PM
RUNMYTA
Jul 15, 2015 07:50 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
surreybrad
Jul 5, 2015 10:36 PM
