help! no fire from coil
well to start with i just finished a v-6 to a lt1 conversion. when i tried to start engine turns over good but no fire from coil. getting power to the coil. also i swapped the entire coil and module from another camaro and it fired right up. put his on my car still no fire. this is a 94 camaro, 94 wire harness computer sent to ion and had programed disabled vats, air, egr, and speed limiter. i am getting about 14 volts from the harness that hooks to the coil. and the same on the module. could someone please please help me. like to hear it run. i have left the rad. and fans, maf, off right now until i hear the heart beat.
Re: help! no fire from coil
Are you getting a signal to the neg side of the coil? It should pulse a test light in you hook the clamp of the test light to the positve on the battery poke the neg wire going to the coil. Where ya at in AL?
