Gear ratio/top speed limiter
Old Apr 10, 2003 | 10:57 PM
z28s's Avatar
Question Gear ratio/top speed limiter
I changed my differential carrier and gear set a while back...i went from a 2.73 to a 3.42, my car has the top speed limiter and unforturatly my top speed now is around 150 km/h...i bought the trans speedo cable drive and driven gears for a 3.42 car and was wondering if that will solve my problem. was also wondering if i disconnect the speedo cable electrical harness if my top speed limiter wouldn't work...any help or advice? thanks
car is a '93 z with a 700r4 (4l60)
Old Apr 11, 2003 | 03:21 AM
Dr.Mudge's Avatar
Right, unhooking the speedo setup will disable the limiter. Try the computing forum for these types of, computer related questions.
Old Apr 11, 2003 | 06:32 AM
Please post generation specific tech questions in the appropriate forum... in this case "LT1 Tech" or "Computer......."
Moving to "Computer......." .....
Old Apr 11, 2003 | 08:18 AM
MyTMous's Avatar
Does your 93 have the 120 or 150 mph speedo in it?
I know the 94 with 120 are limited to 110 or so.
If it came with Z rated tires this limit is not there.
It's in the chip on a 93 and you would need to replace it with one that has the limiter changed.
I know www.pcmforless.com guy does this don't know how much tho,
Old Apr 12, 2003 | 09:50 PM
z28s's Avatar
I have the 120 MPH dash...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
grabbem88
Feb 10, 2015 06:20 PM
ChrisFrez
Nov 30, 2014 08:41 AM
