Fried the ECM
Old Oct 11, 2008 | 02:04 PM
cleangene's Avatar
Fried the ECM
OK, seems I have fried the computer on my 96Z, any one know if I can correct the problem, I have TunerCat, it did this the other day so I disconnected the battery and then I was able to reprogram, but this time it would not let me. The error codes it gives is, C/2, I/2 and H/16.
C/2 was the first one when it failed the first time, the other two was after I disconnected the battery. Did not lose power or connection. Any one have any ideas.
Old Oct 12, 2008 | 09:23 AM
95Blackhawk's Avatar
How do you know you fried it? What happened? There are folks out there (and on this board) who can fix these things IF it is fried.
Old Oct 12, 2008 | 03:40 PM
cleangene's Avatar
will not start and will not let me read or reprogram the ecm.
Old Oct 12, 2008 | 03:50 PM
RUDEDOG's Avatar
Is the ses light working?
Old Oct 12, 2008 | 07:21 PM
cleangene's Avatar
yes, everything is working, the computer made a funny noise when this happen, it made a bumping noise several times.
Old Oct 18, 2008 | 02:54 PM
cleangene's Avatar
New question about connections
Is there a fuseable link or relay between the OBDII under the dash and the PCM in the car, I have another computer now and my programer will not read the PCM nor will my scanner, the car still will not run. like I said the problem came up when I tried to flash a program in, there was a bumping noise that came from the dash area, I think somewhere in the wiring there is a problem, I have checked the wiring diagram and found nothing in between the units, but there has to be some thing that I have missed or a wire burned intwo to keep the laptop and the PCM from talking to each other.
Old Oct 21, 2008 | 07:19 PM
toadies101's Avatar
If u need a PCM i have my 97 TA OBD II I am not using anymore.. i'll let it go cheap.. I converted to OBD I
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
