freescan w/ vista
Old Feb 15, 2007 | 06:28 AM
red 95 z28 lt1's Avatar
freescan w/ vista
does anybody know if freescan works w/ windows vista. if not what other type of software will? god i hope lt1 edit will work when i decide to get a dyno tune!
Old Feb 16, 2007 | 12:52 AM
anyone?
Old Feb 17, 2007 | 11:16 AM
how bout lt1 edit has anyone tried that
Old Mar 8, 2007 | 03:03 PM
ru2slo_99's Avatar
Freescan works with Vista on my computer. I have the AKM USB cable and it works fine.
Old Mar 13, 2007 | 12:05 PM
theratdude64's Avatar
I duno if this helps much but I've run EFI Live to tune a Duramax on my Vista Laptop with no issues
Old Apr 6, 2007 | 06:24 PM
i cant get it to work i have the akm usb cable and had some issues istalling the cable software and then i had issues installing freescan then when i hooked it up to the car it caused a blue screen and had to shut down, help please this sux
Old Apr 12, 2007 | 04:23 PM
ru2slo_99's Avatar
I did not had a problem intalling the cable software or freescan. I have used Freescan several times with my Vista Basic computer with no problems. There is a compatibility function that Vista uses but it is confusing sometimes on how to use it, but I did not have to go that route with Freescan. I had to use compatibility mode for Tunercat though.
Old Apr 12, 2007 | 04:38 PM
how did u go about installing the cable software and freescan if you can explain in detail, im not really computer literate
Old Apr 12, 2007 | 09:08 PM
ru2slo_99's Avatar
If I remember correctly I just put the disk that came with the cable in and went through the installation steps on the sheet Andrew sent with it. I downloaded and intalled Freescan from the website and installed it. If I remember any different I will post back.
Old Apr 12, 2007 | 10:03 PM
i have vista home premium, i compleatly deleted freescan and re downloaded it and still when it opens i get a box that appears saying the system cannot find the files specified, did i do something wrong <someone please help>
Old Apr 13, 2007 | 08:09 AM
vdubois's Avatar
When i was trying out vista i loaded some scanning software and the only way i can get it to run was to execute it in winows xp compatability mode. At that time vista just wasnt a suitable OS for me so i ended up going back to XP. Here is a link to some directions http://www.howtogeek.com/howto/windo...tibility-mode/
You could also run XP in a VM inside of windows vista.
Old Apr 13, 2007 | 06:41 PM
ru2slo_99's Avatar
Go to the start icon on the bottom left hand of the screen and click it, select help and support. Once the help screen pops up type compatibility in the seach function. You should get many options, one being compatibility wizard (it was at the top of the selections for my computer). Run the wizard and it can show you all of the programs that have the option for the compatibility. You should choose the software from the list and follow the steps.
I have been messing with this all afternoon trying to get my computer to work with the wireless internet at school. NO LUCK! But it worked for Tunercat. Good luck.
DSMKilla
May 26, 2015 10:10 PM
timmy39120
May 2, 2015 05:12 PM
DarkHorse
Apr 8, 2003 05:47 PM
Blk94Z28LT1
Mar 15, 2003 11:02 PM
JeffK95Z
Nov 13, 2002 12:50 AM
