FreeScan Question
Old Sep 18, 2004 | 01:03 PM
Jeffs94Z28's Avatar
FreeScan Question
I keep seeing people say if the light goes off the code will still be able to be retrieved, However my light was on then went off and I just recently tried to scan it and I couldnt pull up any trouble codes, until the light came on again. If you turn the car off do the codes leave the system? By the way it was Code 36: High-Res failure.
Old Sep 18, 2004 | 01:22 PM
97Z-M6's Avatar
Re: FreeScan Question
if you have a laptop go to ttspowersystems.com and down load the dx23ee file for you car and pm me and i will email you somehting. it records the data
Old Sep 19, 2004 | 11:02 AM
Jeffs94Z28's Avatar
You have mail.
Old Sep 22, 2004 | 12:54 AM
slimdawson's Avatar
I don't count on freescan catching codes. pcmcomm is a good program for that. And no, your codes will not erase by turning the ignition off. They will after a certain number of times if the code isn't set again though.
Old Sep 23, 2004 | 01:46 PM
smokin5s's Avatar
make sure that your key is on the "on" position before scanning... Free Scan will retrieve codes even if the light goes off unless the code has been cleared.
BigWil
Mar 29, 2015 12:24 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
