Freescan for Electrical Faults
Old Apr 23, 2005 | 12:50 PM
st_paul's Avatar
My car's electric system puts out about 10-11 volts to the accessories and I was wondering is there any way to check the system using freescan? I know I probably have a bad ground somewhere and I want to avoid checking every electrical connection in the car. I have already checked the battery and alternator and about 10 over connections and I am stuck.
Old Apr 23, 2005 | 01:46 PM
st_paul's Avatar
Re: Freescan for Electrical Faults
Anyone tried to do this before? is there a way to check voltage on components through the pcm using a program like freescan?
Old Apr 23, 2005 | 06:40 PM
DieKnow's Avatar
No!
Old Apr 24, 2005 | 12:55 AM
st_paul's Avatar
well that doesn't help. so i guess i have to get out the old voltmeter and check everything?
Old Apr 24, 2005 | 04:16 PM
st_paul's Avatar
is there a better way to do this?
Old Apr 24, 2005 | 11:27 PM
roguedriver's Avatar
How did you know your only getting 10 to 11 volts to your accessories? How much did your altenator put out? You don't have an underdrive pulley, do you?
Old Apr 25, 2005 | 09:55 AM
st_paul's Avatar
no underdrive pully. i do have pcmforless. i tested the accessories with a volt meter. they are at about 10.6 volts. i have a brand new optima battery and a high output alternator (140 amps i think). i had both of them tested by an auto shop and they told me they were more than fine. i am thinking it could be a dying fuel pump but i guess it could be a ton of different things. i am just wondering what the likely causes could be? is there any ways to find out with testing everything?
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
