Formula for A/F ratio??
Old Sep 26, 2002 | 07:14 AM
MARKSZ28's Avatar
How do you know what A/F ratio you are running?? Is there a formula to use--using numbers from LT1-edit and the logging software??
Thanks,
Mark
Old Sep 26, 2002 | 07:20 AM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
The only real way
The only real way to tell what the cars A/F ratio is buy using a wideband O2 sensor. But if you want to know what you have the PCM set for- Open loop can be figured out in the %chanfe air/fuel Vs. rpm table of tunercat. That table is for WOT, there is a formula that you have to use, look in the calibration help section, it will tell you the formula there.
Old Sep 26, 2002 | 07:46 AM
MARKSZ28's Avatar
What about for LT1-Edit??
Old Sep 26, 2002 | 07:47 AM
dayusmc's Avatar
Not Sure.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
