flashing my PCM
Old Nov 23, 2006 | 02:09 PM
  #16
Red on Red WS6's Avatar
Originally Posted by Sporty-X
just to add : no problem with me with Ion, who gave me complete satisfaction on work he did for me (OBD2 to OBD1 conversion, tune, help for sending me cable ...)
my problem is just about this ***ing programming
I will take a look at the cable just in case. I need to load this tune since my Hotcam install
Pierre
I used a couple of his tunes a year or two ago, but I never had to use another tuning software. He always sent the tune as a boot file. Maybe he is doing things different now. Have you asked Ion about your problem? Also if I remember correctly the 30 day trial version of Tuner cat is just to look at and see the type of changes you will be able to make if you buy the software. I don't think it allows you to flash the PCM. I could be wrong though.
Old Nov 23, 2006 | 06:02 PM
  #17
plattted's Avatar
A lot of problems with some "programmers". There is a lot of advertising for some but very little "QUALITY" control from the web site site officials in what is being sold as the answer to an individuals problem. A survey should be taken with users of this site as to what was their expierence with individuals who use this site to make money. And publish the results. A fair request! 93 Z TED AKA PLATTTED
Old Nov 26, 2006 | 02:19 PM
  #18
Sporty-X's Avatar
i'm waiting for a new cable. Is there a way to check the car harness while I will wait for the cable ?
Pierre
Old Nov 26, 2006 | 10:41 PM
  #19
infinitebird's Avatar
The trial version of Tunercat definitely does not come with the $EE file. Unless you have some kind of special trial version that was no one else does, you have to buy that.
Old Nov 27, 2006 | 01:57 PM
  #20
Sporty-X's Avatar
i use only the "winflash 2.15" from Tunercat to read and program the PCM.
I don't think i need more.
Pierre
Old Nov 28, 2006 | 02:15 PM
  #21
Sporty-X's Avatar
How is working the ALDL test and what results this sofware gives ? can it check the port ? the cable ? I tried it on the 2 laptops and 2 desktop i have and it has always failed on the 3 test ?
Maybe i'm using it in a wrong way.
Any help ?
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
