F.a.s.t., Bg3, Accel Dfi Gen7?????
Old Feb 15, 2007 | 08:55 PM
bowtiepwr's Avatar
>I am so confused on which would be the best bang for the buck and the easiest to operate for a Supercharged/N2O LT1.
I know they are all expensive, and cost really isn't that much of a factor (not rich tho), but I really want ease of operation.
I don't want to spend more than $2000.00 give or take a few hundred.
Old Feb 15, 2007 | 08:58 PM
95 Z/28 LT1's Avatar
Super Moderator
Bs3 Ftw
Old Feb 15, 2007 | 08:59 PM
96speed's Avatar
Wrong forum .
FWIW, HPTuners on my Z06 is lightyears ahead of my LT1edit. That's the only experience I have to offer. Not sure why I'm responding though .
Ryan
Old Feb 15, 2007 | 09:01 PM
bowtiepwr's Avatar
Originally Posted by 96speed
Wrong forum .
Ryan
>no its the correct forum.
but I do appreciate your suggestion.
Old Feb 16, 2007 | 07:34 AM
mdacton's Avatar
I have the gen7
Its not all that easy but easier than tunercat....no experience with BS3
Old Feb 16, 2007 | 09:22 AM
Describe the engine and the S/C and N2O setups you plan to use. That will determine, in part what you need. People have managed to use the stock PCM for relatively sophisticated setups.
Old Feb 22, 2007 | 08:51 AM
RealQuick's Avatar
I just picked up a F.A.S.T. w/ WB and White's racing plug N play harnes for $600 Thats what I'll be using. If ya need a hand with anything I am local. Just let me know.
Jon
Old Feb 22, 2007 | 09:01 AM
ulakovic22's Avatar
Best bang for the buck is the stock PCM. It's free and can handle a supercharged LT1 and then you can use an aftermarket ignition set-up for when you want to use the juice.
Old Feb 23, 2007 | 08:24 AM
RealQuick's Avatar
Your right, it can handle a supercharged LT1... but it wont handle it to the engine's potential. Stock ecu wont read boost as you probably know, so you dont have the ability to fine tune the timing in the +gauge pressure areas (above 100KPA). Aftermarket ECU will let you do this. Also, the ability to have a WB O2 control fueling with some aftermarket systems.
Old Mar 2, 2007 | 05:55 PM
blown383's Avatar
subscribing for more info.
-B
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Slayer
Aug 17, 2015 03:55 PM
IROCrdracer
3rd Gen / L98 Engine Tech
13
Aug 17, 2002 09:53 PM
