Extreme fuel trims
Old Aug 19, 2004 | 09:05 PM
weinerschizel's Avatar
Question Extreme fuel trims
I installed a substantial cam in my car (cc306). I'm starting to do some data logging. I'm noticing quite a bit of knock. Especially after 4-5krpm. I also noticed the BLM and INT learns were WAY LEANING down the fuel.
Is it possible if I'm running too rich, that the engine could ping and thus register knock?
Thanks for the help!
Old Aug 19, 2004 | 09:18 PM
97Z-M6's Avatar
Re: Extreme fuel trims
do you have tunercat or lt1 edit.
what are the blms at.
running rich will help stop predetnation.
Old Aug 20, 2004 | 09:57 AM
Question Re: Extreme fuel trims
Ok when I'm experiencing knock at lower RPM (ex 3k and below) my BLM's are at 108. The upper RPM (4k and above) it's knocking with BLM's at 128. I don't believe it's had much of a chance to learn the trims yet though as I don't do too much cruising at 4k and above.
I've got a spread sheet with the data in it. Thanks for your help!!!!
Old Aug 21, 2004 | 11:46 PM
Dan K's Avatar
And the program in the pcm now is?
Stock?
Old Aug 22, 2004 | 02:10 AM
bunker's Avatar
When running too rich the KS does register knock, my understanding is that when you run way too rich the engine starts to lug & vibrate a little which the KS might be picking up as false knock, I've tried this especially in open loop, o2s would read 950mv at cruise & the knock sensor starts going off, while if I run the damb thing even too lean most of them time the ks never goes off because the engine is running smooth & until real knock comes on the KS doesn't see it.
Old Aug 23, 2004 | 07:08 PM
I'm running the stock programming. Thanks for your help guys!!
Old Aug 25, 2004 | 10:37 PM
Where do I go to adjust the fuel in Tunercat?
Old Aug 26, 2004 | 08:47 AM
PoorMan's Avatar
I got a tune for a 306 if u want to use it as a starting point. Just pm me if u want me to send it to you.
JD
Old Aug 26, 2004 | 08:44 PM
jdizzell's Avatar
Correct my if Im wrong, but isn’t 128 blm zero? I mean the pcm doesn’t add or subtract fuel at this cell.
Old Aug 27, 2004 | 07:01 PM
How do I adjust my fuel in tunercat?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Apr 3, 2015 10:54 AM
maybe2fast
Mar 16, 2015 11:59 AM
