Electronic gauges on screen
Re: Electronic gauges on screen
Only certain head units have that capability directly.
However, I guess if yours has video input capability, then you could use a laptop or other on-board PC to send video the the screen, and run something like Autotap or something to do a virtual dash. People do it all the time with PC based MP3 jukeboxes, so why not for diagnostics?
There is.
A PC in a custom case, mounted somewhere in the car, with a remote screen mounted to your dash. That screen could be your in-dash unit if it's got aux video inputs for like an external DVD player or something.
It shouldn't be very difficult.
There is.
Does the head unit have an auxiliary video input?
You at the very least will need a way to do TV out from the computer, either directly or through a converter. Connect from there to the aux video input on the head unit and you should be able to get it working.
No problem. Good luck.
Something that *might* help you.
You can also get a "flying" mouse and use that. It's used for presenters and such who are projecting onto a screen. You'll be using the same concept, just on a smaller scale. It'll take some getting used to, but it should work.
The highest voltages used inside a normal PC is 12v DC. There are some 5v and 3.3v lines as well. If you hunt down the pinouts for the power supply, you can figure it out. All you have to do is to reduce the 12v down to 5 or 3.3 and you should be able to wire the PC straight into the automotive electrical system without the need to an inverter.
The only problem? When you turn the car off, the PC will turn off, and that's NOT good for it. So you'll have to remember to shut the PC down before turning the car off.
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
